drain antifreeze V4 cologne
Postby grub3r » Sun May 14, 2017 2:42 pm
Hi,
reading the book, it says draining plug on radiator but it does not exist
it aslo says draining plug on engine beside to oil-filter, which aslo missing..
how to drain the system on Cologne V4?
is it only the hose on the bottom of the radiator? But will the engine drain as well?
regrads.
grub3r
Re: drain antifreeze V4 cologne
Postby bulls in transit » Mon May 15, 2017 8:34 am
My cologne's got a 13 mm plug each side of block just below head on rear two cylinders on block,also got a drain plug on rad,mines the later cologne(post fall 67),don't know if earlier ones differ.
bulls in transit
Postby Altransit » Mon May 15, 2017 9:51 am
I've not seen a drain plug on a radiator for years, so disconnecting the bottom hose at the radiator pipe is the way ahead. I always took the opportunity to flush the engine and rad using this access point, whilst it was disconnected 8)
Postby grub3r » Mon May 15, 2017 12:07 pm
Hi,
mine is 1977 1.7
will check these points and report back.
Would the engine flush through the radiator access?
regards, DB.
grub3r
Postby bulls in transit » Mon May 15, 2017 12:32 pm
The drain plugs on block are directly under the rear two most spark plugs,next to rear engine core plugs,the one on filter side is hard to see,its behind external metal water pipe/hoses.
Radiator drains right next to bottom hose so removing hose does same job on mine.
Water in heads/heater won't drain from bottom hose,but will from block,found this out when changing heads on mine!
bulls in transit
Postby Altransit » Mon May 15, 2017 2:38 pm
bulls in transit wrote: Water in heads/heater won't drain from bottom hose,but will from block,found this out when changing heads on mine!
Presumably, you would need to remove the thermostat to drain it completely via the bottom hose :?: :wink:
Postby grub3r » Mon May 15, 2017 2:57 pm
it says to undo the radiator-drain plug and block-drain plug to flush the engine in the Haynes book..
regards.
grub3r
Return to Mk 1 & 2
