Diff ratio (s)
Diff ratio (s)
Postby Johny89 » Sun May 06, 2018 7:18 am
So I searched the forum (and Google ) but couldn't find the answer anywhere
I have this tag on my diff from what can I see the ratio on it?
As most want is a "higher" top speed.
What I want is lower rpm at top. And because its a 5speed doing 60km/h in fourth for hills but having it too hard in fifth o thought if I gear up the rear end I can gain some in fourth.
Speedo is now by ten percent off so I don't worry about that.
The tag on the axle.
Johny89
Re: Diff ratio (s)
Postby Ralph.9 » Mon May 07, 2018 8:22 am
Your ratio is 4.4 to 1.
Ralph.9
Re: Diff ratio (s)
Postby dumper » Mon May 07, 2018 9:42 am
Looking at your outher post I don’t think you York engine has enough power to pull a higher diff ratio you maybe better lowering it so it will pull better in 5 th gear your zf box is 1to1 5 th gear the standard transit box are overdrive in 5 th was this a factory setup or has you or previous owner put a engine and box out of a A series
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Re: Diff ratio (s)
Postby Johny89 » Mon May 07, 2018 11:21 am
They come from an a series. Not original. Which made me think it is restricted to go faster (speedo is off but shows max 95)
I do have some sort of valve in the exhaust pipe aswell and it route first to the front before it goes backwards. ..
Johny89
Re: Diff ratio (s)
Postby dumper » Mon May 07, 2018 12:14 pm
That may have been a exhaust brake very doubtful it’s had a speed limiter fitted look at the throttle cable if it goes from the pedal and straight to fuel pump and no other unit in between someone on the A series may be of more help as to what was fitted to them
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Return to Mk 1 & 2
