pinto wiring
pinto wiring
Postby Boffin » Fri May 25, 2018 9:38 am
Hi there, I've got a pinto out of a mk2 transit (it was A reg) it has electronic ignition, I've got the module which was by the passenger headlight and the connector to the distributor. Does anyone know how to wire it up? Or have a mk2 transit wiring diagram. Also the connector on the distributor has 3 wires, where as the other conector only has 2? It was running like that in the mk2. Thanks for any help.
Boffin
Re: pinto wiring
Postby Chug » Fri May 25, 2018 10:55 pm
I have this on an old piece of paper saying pinto electronic ign wiring, its for the wires from the electronic module don't know if its any help?
green to coil
black/green to starter +
black to coil ign
brown to earth
black/red to distributor multiplug
green/yellow to distributor multiplug
Chug
Re: pinto wiring
Postby Boffin » Sat May 26, 2018 2:56 pm
Cheers Chuggy, I'll check that out. Thanks mate. Will report back when it's running :)
Boffin
Return to Mk 1 & 2
