mntranny wrote:Update[b][u][/u][/b]
For this afternoon, I went out and checked the engine over and found the clamp holding the hose output of the water pump was slightly lose, so I replaced the hose and clamp as a precaution.
Next I turned the engine over and saw something I have never seen before.
The engine was turning over but the timing pulley and therefore the waterpump/alternator were not turning.
As the engine is turning over and will run, I am suspecting that there may be a some gearing between the Crankshaft and the timing that has failed.
Any recommendations of what to do next?
Many thanks for the feedback so far.
