Wiring Diagram MK2 2.4 Diesel
Postby Tomfish » Sun Jun 24, 2018 8:05 pm
Hi,
Is there anyone that can help me out with a MK2 2.4 Diesel '78 wiring diagam? Especially the pre-heating circuit of the inlet manifold before starting. I think the relay that is controlling the the pre-heating failed. Got no light on the das nor is it pre-heating (which makes is very hard to start).
Thanks!
Tomfish
Re: Wiring Diagram MK2 2.4 Diesel
Postby Neil » Tue Jun 26, 2018 5:46 pm
the pre heater uses 3 relays and also a resistor on the pre heater plug
Neil v6
Neil
Postby Tomfish » Sun Jul 01, 2018 1:37 pm
Neil wrote:the pre heater uses 3 relays and also a resistor on the pre heater plug
Hi Neil,
Thank for kicking me in the right direction, however I do not completely agree with your answer. I reversed engineered the wiring for the glow plugs today and I would like to share it with the rest of you. The wiring is quite simple. The main component is the Bosch 0333402001 glow relay in combination with a 'normal' relay. The terminals of the glow relay are as below.
15 = +12V from ignition switch
30 = +12V straight from battery
31 = Negative from battery
50 = Starter control (+12V when starter motor being enabled)
86 = Connection to glow plug relay (+12V when enabled)
K = Glow indication light on dash (negative when enabled)
G = Check wire if glow plugs are being enabled (+12V when enabled)
My relay seems to be broken. Will try to fix it by replacing the broken resistor...
Tomfish
Postby Neil » Sun Jul 01, 2018 5:43 pm
no worries I took the reply/answer out of the FORD workshop manual for the 2.4 York diesel :?:
Neil v6
Neil
Postby Tomfish » Tue Jul 03, 2018 5:39 pm
Neil wrote:no worries I took the reply/answer out of the FORD workshop manual for the 2.4 York diesel :?:
Need one too!
Tomfish
Postby Johny89 » Wed Jul 04, 2018 5:20 am
Haynes manuals are available on amazon. I got mine there at a decent price.
I should take a look on my pc but I think there is part of a manual in pdf I got on it. Will return to you this evening.
Johny89
Return to Mk 1 & 2
