I can't get my steering box arm off
Postby buxvan » Wed Jul 04, 2018 6:24 pm
I'm trying without success to do the above. Have soaked the spindle in various penetrating oils, tried 2 different 2 leg pullers & a blowtorch but no joy.
Any suggestions please ?
Is there a special puller made for this ?
By the way, it's a mk2 facelift swb
buxvan
Re: I can't get my steering box arm off
Postby DodgeRover » Wed Jul 04, 2018 6:56 pm
Have you tried holding the head of a sledge hammer at one side of the shaft and twatting the other side with a lump hammer like you would do a track rod end?
DodgeRover
Postby buxvan » Wed Jul 04, 2018 7:22 pm
Cheers dodge, I don't really want to put any sideways pressure on the steering box in case I wreck it.
At the moment I've got a 2 leg puller tightened up very tightly & am giving the shaft regular doses of plus gas & the occasional belt on the end of the puller. I'm also giving myself regular doses of beer.
How's the Lwb ?
buxvan
Postby dumper » Wed Jul 04, 2018 8:14 pm
Back in the when we got a bad one we cut them off but I was not paying for them we would be fitting a new box so the price of a arm was cheaper the mucking about but maybe if you can get a two leg puller with a slide hammer on it it may do the job
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby Muttley » Wed Jul 04, 2018 9:46 pm
I have a hydraulic puller, just the job I find :wink:
Expert burns receiver.
Bodger Extraordinaire!!
Fallen in love/hate with Mk6s
Muttley
Postby Luke » Wed Jul 04, 2018 10:49 pm
this is the puller i made :D
not failed me yet
Postby Johny89 » Thu Jul 05, 2018 11:22 am
Indeed look for a pitman arm puller. Put tension on the puller and then hit with a brass Hammer on the arm.
Johny89
Postby buxvan » Thu Jul 05, 2018 2:33 pm
Just looked up pitman puller on ebay, do you know what size i will need as they come in various widths..
Cheers
buxvan
Postby DodgeRover » Fri Jul 06, 2018 9:10 am
buxvan wrote:I'm also giving myself regular doses of beer.
How's the Lwb ?
Beer helps! the mk2 is doing my head in a bit! The pinto is knackered and smokey and had started to do a head gasket, but being a pinto it's keeping going! I've got a good spare to go in but it's in Derbyshire...I'm trying to get hold of an overdrive box and the bits to make it fit to swap in at the same time, problem being I don't think the 200 mile trip up will end well - luckily I've got recovery.
The body is starting to go a bit as well and I've got nowhere to work down here, to be right it needs a pair of lower rear quarters (which I have) and inner and outer rear valances (which I need to find) along with a front wing (got that too). Just looks really run down which isn't how I like stuff appearing.
I'm actually looking for a good mot'd Lwb mk3 so I can run that for work while I take the mk2 upto Derbyshire for a while to spend sometime working on it.
How's yours coming on?
DodgeRover
Postby Johny89 » Sun Jul 08, 2018 11:28 am
Actually I don't know the size. You should measure the width of the arm and look what fits. I have one for my F150 was listed where I get my parts haven't tried it on the transit yet.
Johny89
Postby buxvan » Tue Jul 10, 2018 1:52 pm
Well, I borrowed a hydraulic puller today & still not budging
buxvan
Postby conrod » Wed Jul 11, 2018 9:05 pm
I had one that was real tight a couple of years ago. Put a big hydraulic puller on it, and cranked it up tight, THEN put some heat on it. Needed both at the same time to release.
I would suggest if that doesn't work, you will have to cut it off with a cutoff wheel. Run a cut down one side all the way through, being careful not to run into the splines. Same on the other side. Tap it with a hammer and it will fall off.
conrod
Postby buxvan » Thu Jul 12, 2018 11:05 pm
DodgeRover wrote:Have you tried holding the head of a sledge hammer at one side of the shaft and twatting the other side with a lump hammer like you would do a track rod end?
Wey hey! It's off, chap who leant me the hydraulic puller came over & had a go, it still wouldn't budge so I held a sleeve hammer on one side & he hit the other side with a club hammer. Came free on the 4th wallop. He used to be a farm machinery mechanic & is used to combine aaaarrvesters !
Thanks for the advice everyone.
buxvan
Return to Mk 1 & 2
