[Project] MK2 '83 Pinto campervan build
Postby Wolfkop » Mon Aug 20, 2018 1:23 pm
He Guys,
just bought a '83 MK2 old ambulance, 2.0 pinto. I want to make a campervan out of it:
- Doing some stuff on the interior to make it possible to sleep;
- Making sure the engine keeps on running;
- Do some things for better handling, it is going everywhere at the moment;
- Replace missing window, get rust off of the window frames & get the rust of the plate work.
The frame is good, no rust. Engine runs oke, gonna do some basic maintenance at first. Looking into things to make it more reliable, tips are welcome.
Gonna leave it on petrol, because I live in Amsterdam (Netherlands) and Diesel is not allowed into the city for cars from this age.
Keep you guys updated!
Wolfkop
Re: [Project] MK2 '83 Pinto campervan build
Postby Wolfkop » Mon Aug 20, 2018 3:58 pm
Getting the floor in:
old;
new, have to nail it when the bedframe is finished and I can see that everything fits:
welding the frame for the bed and drawers:
main frame:
Wolfkop
Postby Neil » Mon Aug 20, 2018 6:25 pm
looking good :D
Neil v6
Neil
Postby Tomfish » Tue Aug 21, 2018 2:53 pm
Hurraaay, another dutchman! Succes met je project! (Good luck with you project)
Tomfish
Postby DodgeRover » Thu Aug 23, 2018 9:07 pm
The pinto could benefit from an unleaded cylinder head and probably an LPG conversion.
DodgeRover
Postby robbie.cee » Thu Aug 23, 2018 10:30 pm
I can totally recommend replacing pionts in distributor with a €40 set of electronic ignition module. Loads of power right from low speeds up. Also 6 degree static timing with vacuum rrmoved from distributor and plugged temporarily!
Sent from my SM-G920F using Tapatalk
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby Wolfkop » Sun Aug 26, 2018 8:32 pm
Tomfish wrote:Hurraaay, another dutchman! Succes met je project! (Good luck with you project)
Thanks! Good to see some other MK2 owners from the Netherlands here! Will def. follow your project!
DodgeRover wrote:The pinto could benefit from an unleaded cylinder head and probably an LPG conversion.
I've seen that one before. I need a Pinto from a Sierra or so for that right? I will begin to search for one here in the Netherlands.
robbie.cee wrote:I can totally recommend replacing pionts in distributor with a €40 set of electronic ignition module. Loads of power right from low speeds up. Also 6 degree static timing with vacuum rrmoved from distributor and plugged temporarily!
Sweet, could have come with this one my self. Just did it on my old Motorcycle. Let me look into that one.
I want to have my 'steering' a bit better as well, but a conversion to the MK3 seems a bit to much with the welding at the frame. I think im going to search for the heavy duty shocks off a 3.0 liter, hope those are a bit stiffer than the ones I got right now. Does anyone know of other upgrades besides the MK3 conversion?
Wolfkop
Postby Wolfkop » Mon Aug 27, 2018 7:30 pm
Would something like this work instead of searching for the Sierra parts? http://www.ccee.nl/accuspark/Accusparkpage1.htm
Wolfkop
Postby robbie.cee » Fri Apr 05, 2019 11:24 pm
If it is a small ring with 4 magnets in it and a pickup coil that replaces points then yes.
Weird thing is...
Ignitiin power to high voltage coil '+' post. This wire also to the new coil in distributor. The other wire to high voltage '-' .
It somehow magically produces the ground pulse to fire sparks...
Work great and massive power gain from 1rpm to 6500!!
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Fri Apr 05, 2019 11:37 pm
Like thisImage
Had
MAKE IT FIT
robbie.cee
Postby jonochap » Sat Apr 06, 2019 7:34 am
Muttley put 4 helper springs as an additional support on my mk1...that made a big difference but also replaced the rear springs and all struts with heavy duty
Owner of not so troubled puk :)
jonochap
Return to Mk 1 & 2
