Indicator switch mk1
Postby christojnr » Thu Oct 25, 2018 3:51 pm
Hello gents I have recently found out that the indicator lever has a switch inside can anybody tell me what it's for
Sent from my BLA-L09 using Tapatalk
christojnr
Re: Indicator switch mk1
Postby Altransit » Thu Oct 25, 2018 9:09 pm
Isn't it for flashing the headlights :?:
Postby christojnr » Fri Oct 26, 2018 5:15 am
Altransit wrote:Isn't it for flashing the headlights :?:
No idea
christojnr
Postby dumper » Fri Oct 26, 2018 6:19 am
From memory the indicator switch is also dip/ main beam /flash headlights and on the end horn switch I also remember that their are a lot of different wireing set ups on the plug we used to have problems getting the right one
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby christojnr » Fri Oct 26, 2018 6:31 am
dumper wrote:From memory the indicator switch is also dip/ main beam /flash headlights and on the end horn switch I also remember that their are a lot of different wireing set ups on the plug we used to have problems getting the right one
Mine doesn't have the bright features so it's gonna be the horn thanks
christojnr
Postby christojnr » Thu Nov 01, 2018 5:27 am
Hello after cleaning everything I found that indeed it is the same can you maybe help me with a wire diagram
christojnr
Return to Mk 1 & 2
