Mk2 Differential
Mk2 Differential
Postby jawor88 » Wed Dec 19, 2018 1:41 pm
Hello,
Could anyone help to prove - is it possible that the diff's ratio is stamped on the ring ? the link to the foto bleow - do you think is it true ?
Regards
https://zapodaj.net/2e6bf86eebc7e.jpg.html
jawor88
Re: Mk2 Differential
Postby Luke » Wed Dec 19, 2018 2:44 pm
i would guess yes that will be the ratio but if you want to be sure just count the teeth on the crown wheel and the pinion and divide them you should confirm the ratio
Postby Ralph.9 » Thu Dec 20, 2018 8:25 am
Yes all CWP'S are matched pairs & have the teeth numbers stamped on the side.
Ralph.9
Return to Mk 1 & 2
