What brakes do I have
Postby Shed_Transit » Tue Mar 19, 2019 9:38 am
Hi all,
I have an ex-Malta Mk1 twin wheel bullnose and trying to find out what brake calipers / master cylinder and servo I have, can anyone identify what I have fitted (not sure whether it's Mk1, I've been told it's mk2 kit) I need to sort either a rebuild or new calipers / master cylinder - so any advice on parts suppliers would be great.
Pictures;
Thanks,
Steve
Shed_Transit
Re: What brakes do I have
Postby Soren » Tue Mar 19, 2019 12:38 pm
Hi
Here is an link where you have a chance to find what you need
Cheers Søren
https://www.motomobil.com/my-ford,2188.html
Transit MK 1 1977 Essex V4 2,0 Autocamper
Volvo V60 D2/D3 2013
Harris Magnum 2 GPZ 1100 1984
Kawasaki GPZ 1000RX 1988
Aberdeen Angus cattle approx 35
MF 135 1973
David Brown / Case 1390 1982
Soren
Postby Neil » Tue Mar 19, 2019 7:30 pm
servo looks single wheeler :?:
Neil v6
Neil
Postby conrod » Tue Mar 19, 2019 7:54 pm
4 pot calipers with solid discs obviously, and that servo looks small like Neil said! AP/Lockheed master cylinder, and there are many different bore sizes available for this, so best bet is to remove and measure before ordering a new one. From memory I think the 4 pot calipers all shared the same piston size, 41mm ????? The brake discs are the same as any other Transit with solid discs, ie. all Mk2's.
conrod
Postby Shed_Transit » Tue Mar 19, 2019 10:04 pm
Thanks Guys, as the calipers are knackered I'm up for a replacement what would you recommend as a straight forward bolt om replacement? I've read on here that LDV convoy calipers fit? What year - as I have a late 02 or 03 scrapper in which I removed the duratorq to install in this mk1. What master cylinder / servo would you suggest?
Many thanks for the advice!
Steve
Shed_Transit
Postby Neil » Wed Mar 20, 2019 7:48 am
the biggest bore for the twin wheeler think its 23 mm :?: Lockheed but some later ones had a bendix servo and cylinder either servos are hard to find new but if you find a secondhand one they can be re conditioned
Neil v6
Neil
Return to Mk 1 & 2
