MK 1 FORD TRANSIT 5 SPEED BOX OPTIONS
Postby fastlane » Fri May 24, 2019 8:13 pm
Good evening,
i hope you can help in my request. i own a 1971 ford transit camper i recently have had my 1.5 V4 engine taken out and replaced with a 2 litre V4 ( 1969 ish) also a 4 speed box fitted. i have taken the van for a drive today and the van really needs a 5 speed box. it goes well through the gears but once it gets to 4th gear it is revving high as it needs that 5th gear to allow it to cruise and will sound quieter and run more efficient rather than constantly revving high in 4th.
my question is can anybody recommend what 5 speed box would fit straight on the bell housing from another vehicle. i was thinking maybe Capri??
any advice would be much appreciated
also i have a 1.5 V4 engine and gear box for sale if anybody could put this to good use. the engine and gearbox were both working ok
have a nice weekend
Daniel
07894815539
fastlane
Re: MK 1 FORD TRANSIT 5 SPEED BOX OPTIONS
Postby Luke » Fri May 24, 2019 8:49 pm
you can fit the type 9 box with a few mods and a transit linkage but they are rare
what ratio back axle have you got?
Postby dieselhead123 » Fri May 24, 2019 9:48 pm
fastlane wrote:Good evening,
have a nice weekend
Daniel
07894815539
See this thread regarding fitting the Mt75 five speed gearbox from the Mk3/4/5 Di Transits to the Essex V4/6 engines;
viewtopic.php?f=3&t=105677
Assembly/fitting instructions here;
viewtopic.php?f=31&t=140973
Using the Mt75 in a V4 Mk1 will give you an 'overdrive' 5th gear together with a low cost robust gearbox.
Adapter plates and the necessary installation hardware are available as a kit from ourselves, either PM us or use the hyperlink in our signature below for more information.
Nice looking van by the way,
Postby Neil » Sat May 25, 2019 6:55 am
type 9 saves cutting the floor
Neil v6
Neil
Postby Ralph.9 » Sun May 26, 2019 5:43 pm
I have a couple of Transit type 9 boxes with either Pinto or diesel bell housing. Your easiest option is 4 speed with overdrive as they are available with V4 bellhousing.
Ralph.9
Postby Soren » Sun May 26, 2019 6:38 pm
Hi Ralph
Do you know the name of this overdrive box ? and what car it is possible to get it from ?
Cheers
Søren
Transit MK 1 1977 Essex V4 2,0 Autocamper
Volvo V60 D2/D3 2013
Harris Magnum 2 GPZ 1100 1984
Kawasaki GPZ 1000RX 1988
Aberdeen Angus cattle approx 35
MF 135 1973
David Brown / Case 1390 1982
Soren
Postby Ralph.9 » Mon May 27, 2019 6:48 am
They were fitted to MK1 MK2 & MK3 Transits, it called a Laycock overdrive & its fitted to the heavy duty type F gearbox. I can get you picture of one later this week. I have fitted one to my MK1.
Ralph.9
Postby fastlane » Mon May 27, 2019 3:36 pm
hi,
yes that would be most useful,
Daniel
fastlane
Postby Ralph.9 » Tue May 28, 2019 6:14 am
Ok, I have also fitted a 3.5 ratio diff which makes big difference.
Ralph.9
Postby Soren » Tue May 28, 2019 5:25 pm
Hi Ralph
Do you have any pictures you will share ? of what to do
Cheers
Søren
MF 135 1973
Soren
Return to Mk 1 & 2
