Mk2 Chassis Cab
Mk2 Chassis Cab
Postby HIGHCUBE » Thu Jul 18, 2019 4:23 pm
Hi My mechanic has a Mk2 chassis cab, thinking of restoring. But chassis is in bad way. I can find front chassis rails. Is there anywhere to source rear chassis rails.
Does a MK 3 match up.
Will
HIGHCUBE
Re: Mk2 Chassis Cab
Postby Luke » Thu Jul 18, 2019 10:15 pm
not 100% sure but i think it will, i had the same issue with my old mk1 pickup ended up getting a mk1 chassis off a camper and welded it on
the mk2 is the same but i seem to remember measuring a mk3 and thinking it would fit :D
Re: Mk2 Chassis Cab
Postby HIGHCUBE » Fri Jul 19, 2019 9:43 pm
Cheers.
Thought about donor route. Shame to keep chopping them all up for spares. Not many left.
Maybe only option.
Cheers.
HIGHCUBE
Re: Mk2 Chassis Cab
Postby HIGHCUBE » Sat Sep 14, 2019 9:09 pm
Hi All
Does anyone know if the chassis rails, on a 100 chassis cab are the same size as a 190 Chassis cab. Is it just the components and plating that defines the weight.
IE can you use a single wheeler to doner a twin wheeler..
Many Thanks
Will
HIGHCUBE
Re: Mk2 Chassis Cab
Postby Ralph.9 » Sun Sep 15, 2019 7:46 am
No the single wheel chassis is a totally different design to a twin wheel.
Ralph.9
Re: Mk2 Chassis Cab
Postby HIGHCUBE » Sun Sep 15, 2019 8:37 am
Ok cheers.
HIGHCUBE
Return to Mk 1 & 2
