Just been towed back, again! This time due to not being able to find a gear. So looking for some advice before the local mechanics get there hands on it
So I can select all gears when engine is off, but can't when the engine is on which suggests to me an issue with the clutch. It happened when changing from 3rd to 4th and at first I thought I'd knocked the gear stick out - my regular mistake! But after pulling over, I checked and that was fine.
It's the pre-1970s rod style clutch linkage and this all appears to be intact and moving correctly when pressing the clutch pedal, so I'm thinking it's something in the clutch itself.
Fortunately the original owner (of 40+ years), kept a log book - what a legend! I've attached the logs for the clutch: new one in 1985, another in 1989 with new engine and a renewal in Sept 1996. It might have had some work since but I wouldn't know. The bits I can read from the logs say its a laycock type, 8 1/2 normal duty. Doesn't mean much to me, but there are part numbers which will help should I need anything,
I know there could be all sorts happening here but I'm reaching out to see if anyone else had a similar issue before, and if so any advice? I'm mainly interested in what sort of parts I might need if suggestions are even possible.
Thanks in advance guys
