fuel and temp gauge issue
Postby pockets » Thu Aug 29, 2019 5:13 pm
I have an issue with the fuel and temp gauge, neither seem to work ,i was wondering as neither of them operate could there be a particular issue with the wiring or electronic circuit , is there a test i an carry out ? already tried the groud test on the sender end with no joy.
pockets
Re: fuel and temp gauge issue
Postby pockets » Sat Sep 14, 2019 1:44 pm
bump
pockets
Postby DougT » Sat Sep 14, 2019 8:15 pm
There is a voltage regulator which feeds both gauges. On Mk1 it is a box on the back of the speedo and I would guess somewhere on the speedo cluster for the Mk2.
If this fails then neither gauge will work.
Doug
DougT
Postby pockets » Sat Sep 21, 2019 4:27 pm
ye ive located the gauge voltage regulator ,replacements are quite rare and expensive so have had a go at repairing it, one of the pins on the transistor was burnt out so ive replaced the component , , hopefully the diode and capacitor still function , have yet to reattach to dash so havent tested it yet . will let u know how i got on. job is for a friend.
pockets
Postby DougT » Sat Sep 21, 2019 10:18 pm
If you can mend it then that is the best solution.
I don't know if this might work but the voltage stabiliser/regulator for the Smiths instrument cluster in mini, land rover, mgb etc is more common and seems to be a lot cheaper. My guess is that it gives the same voltage and would work, but it is only a guess.
Doug
DougT
Postby pockets » Wed Sep 25, 2019 7:53 pm
well apparently it worked so thats good, if anyone wants one repaired pm me .
pockets
Return to Mk 1 & 2
