sam l wrote:It's always run with the temp needle at the lowest end of the normal scale. The temp gauge works, and the thermostat is not stuck open, although it may be operating too soon.
Inline Boarding Portugal wrote:sam l wrote:It's always run with the temp needle at the lowest end of the normal scale. The temp gauge works, and the thermostat is not stuck open, although it may be operating too soon.
It happens exactly the same with our '85 DI MK2. (although, we really don't know if the thermostat is stuck or not...)
We can see slight variations on the gauge, from "seems to be dead" to "just the start of the scale"...
It's weird, because on our's '81 (not-DI) MK2, after a while with the engine running, the gauge indicates half scale.. And when running, if you pull it on a hill, the temp will rise almost to the high end of the scale...
WEIRD..
Anyone knows what is this all about?
sam l wrote:I'm going to stick a new thermostat in next week, will let you know if this has any effect.
