by dumper » Fri Jan 19, 2024 11:00 pm
On my mk 3 I fitted a Lucus servo glade system back in the day it was a set they was off my xr3i originally as the door on the mk 3 was recessed behind the regulator I had to make a plate to fit it on it used the complete Ford winder system you just removed the handle fitted a hexagon driver onto the splines and the motor drive unit dropped over the top that had a flexible driver to the motor you fitted inside the door it was a bit of a faff Johns mk2 set up looks a better way to do it .
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
