V4 Essex crank
V4 Essex crank
Postby Soren » Sun Dec 08, 2019 7:18 pm
Hi
Does anyone know if it is possible to use an alternative crank in a V4 Essex?
Søren
Transit MK 1 1977 Essex V4 2,0 Autocamper
Volvo V60 D2/D3 2013
Harris Magnum 2 GPZ 1100 1984
Kawasaki GPZ 1000RX 1988
Aberdeen Angus cattle approx 35
MF 135 1973
David Brown / Case 1390 1982
Soren
Re: V4 Essex crank
Postby dumper » Mon Dec 09, 2019 1:39 am
I don’t no about a alternative crank but if you come to fit new main shells make sure you get the right thickness of the backing on them as the journals in the block the are line board to different diameters we had a crank re ground and new shells suppled wrong and had a lot of play
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Re: V4 Essex crank
Postby DougT » Sat Dec 14, 2019 10:11 am
I'm not sure what you mean by "alternative". I think it might help if you could tell what you are trying to achieve ?
Doug
DougT
Re: V4 Essex crank
Postby Soren » Sat Dec 14, 2019 12:50 pm
Hi
That's because jrg bought a 1.7 Essex and it's obviously too small for my Transit mobile home where there is now a 2.0
I have long had a dream of injecting and electronic ignition and what else could be fun to play with so with the 1.7 I would make it for the project
So if there was / is an alternate crunch it was something to do now, so that's my question
Søren
MF 135 1973
Soren
Re: V4 Essex crank
Postby Neil » Sun Dec 15, 2019 9:38 am
Soren wrote:Hi
Søren
throw them both away and fit the Essex v6
Neil v6
Neil
Re: V4 Essex crank
Postby Soren » Sun Dec 15, 2019 10:51 am
Hi Neil
Yes, that is an easy way, but i think i will give the V4 a shot
Alternative i can put on a turbo
Søren
MF 135 1973
Soren
Return to Mk 1 & 2
