Mk3 engine to a Mk2 Transit, posible?
Postby straydog » Fri Dec 27, 2019 4:52 pm
Tentative question guys.
I'm thinking of buying an old Mk2 Transit campervan, problem is the engine is knackered.
I also have a Mk3 Transit I have owned since new, this one rotted away around my ears, Long story:-(
But the engine is fine and still runs great, with fairly low miles.
My queston is, how easy would it be to fit the Mk3 engine to a Mk2?
Or even if it's posible.... :roll:
I obvously have all the running avalable from the MK3, ie Engine, Gearbox, Propshaft, Rear Axle etc.
Any ideas or advice.
Cheers and Happy New Year guys
CVD
straydog
Re: Mk3 engine to a Mk2 Transit, posible?
Postby Neil » Fri Dec 27, 2019 5:34 pm
easy :!: :!:
Neil v6
Neil
Postby straydog » Sat Dec 28, 2019 10:04 am
Easy....lol, Easy for you to say.
Apart from the engine, do I need anything else, gearbox etc?
Any links you may know of, I did a search coudn't find anything usefull
CVD
straydog
Postby dumper » Sat Dec 28, 2019 12:49 pm
It’s some time ago so can’t remember any major problems I fitted a 2.5 di in a York engined mk2 all we changed on the front of the engine was the water pump with the threads on to take the viscous fan I think we used the 4 speed clutch on the di flywheel at a later date we fitted a mk3 overdrive box as we didn’t have the overdrive gearbox xmember we cut the mk2 one and lowered its centre mounting point to clear the o/d unit I can’t remember if the prop was a straight fit from the mk3 or we had the mk2 modified by prop shaft specialist.
I have not fitted a 5 speed into a mk2 but I think it has been done by welding the mk3 gearbox tunnel into a mk2 not sure if that applies to mt 75 and the early 5 speed you have both vans so will have all the parts to do the job so as Neil says should be easy .
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby straydog » Sat Dec 28, 2019 5:15 pm
Thanks for that, think I wait till I got the Mk2 on the drive to look more seriously.
Didn't want to jump in till I had some idea if it was possible.
Cheers CVD
straydog
Postby Neil » Sat Dec 28, 2019 5:26 pm
remove the bonnet followed by the front panal then its all in easy reach
Neil v6
Neil
Postby Chug » Sun Dec 29, 2019 11:52 am
see Retrohowla's thread on fitting 2.5di into mk2 here
viewtopic.php?f=3&t=17759&c=1
Chug
Postby straydog » Sun Dec 29, 2019 3:44 pm
Cheers... 8)
CVD
straydog
Return to Mk 1 & 2
