Need advice and Help
Postby save-blue » Wed Apr 01, 2020 10:53 am
So the van failed its mot a while ago, when you see the pictures you can understand why ! i dont mind doing a fe patch welds but this looks like a lot more than that ? look for advice or even better some local ish to colchester essex that can do the work for me ?
here are a few picture to get things started !
really appreciate any help
Your better to have and not need, than to need and not have. :D
save-blue
Re: Need advice and Help
Postby save-blue » Wed Apr 01, 2020 10:56 am
more pictures
save-blue
Postby Adam mk1 » Wed Apr 01, 2020 4:30 pm
Hi there im not near you but am an experienced welded of 30 years and specialise in restoration welding and also own a mk1 transit and have done similar work on a mk2 i owned in the past, you could put patches over the top but wouldnt be very strong would be a bodge and wouldnt last long, the front spring hangers are double skined, leaf springs would need dropping at front to replace both hangers these would need to be made from scratch also cross member needs doing, i replaced all this on my mk2, don't underestimate the work and time needed, templates for metal, cuting, shaping, drilling welding etc and ut all needs to be replaced 100% inline or the axle wont bolt up straight and it will never drive straight, i live in Portsmouth my workshop is in Winchester, if you want to save your van and you want it done properly i could do it for you, but you would need to get it too me, i have a van im doing on here to see my work, look up adam mk1 ok hope that helps
Adam mk1
Location: Live in southsea Portsmouth, work nr Winchester
Postby Adam mk1 » Wed Apr 01, 2020 4:32 pm
Im also the welder on the NASCHARGER on YouTube
Adam mk1
Postby Neil » Thu Apr 02, 2020 8:59 am
if you really like the van spend the money,, otherwise :arrow: let someone else have the pleasure
Neil v6
Neil
Postby buxvan » Sun Apr 05, 2020 7:26 pm
I feel your pain. Hope you get it sorted. My mk2 wasn't half as bad & today I've just finished my engine rebuid.
buxvan
Postby save-blue » Fri Apr 24, 2020 8:49 am
The van is currently in the garage having the work done :D
pictures to follow !
save-blue
Return to Mk 1 & 2
