Mk2 Factory diesel front springs & tailgate panel please
Postby Adam mk1 » Sun Jun 21, 2020 2:04 pm
Im fitting a di in a mk1so need factory diesel front springs or v6 ambulance type and also am converting rear doors from barn to tailgate, so need filler panel please, thanks Adam
Adam mk1
Location: Live in southsea Portsmouth, work nr Winchester
Re: Mk2 Factory diesel front springs & tailgate panel please
Postby dumper » Sun Jun 21, 2020 3:21 pm
Not sure but if both mk1&2 don’t forget the spacer blocks that go between spring and axle it’s a long time ago but I think the Ford parts department told us that the spacer block and longer u bolts was the only difference between petrol and diesel or it may have been difference between Perkins and York engine
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby Adam mk1 » Sun Jun 21, 2020 6:10 pm
Hi dumper, thanks for your reply
&info
When i fitted a di in my ex AA 120 mk2, before changing the pinto i fitted springs from a v6 ambulance that had been broken up, & i drove it like this for a week or so, and with those springs fitted and still with the pinto it looked like a cross between a 4x4 transit or one without an engine if you get what i mean the camber of spring was far greater and that was without spacer blocks
Adam mk1
Postby Adam mk1 » Sun Jun 21, 2020 6:11 pm
Adam mk1
Postby Adam mk1 » Sun Jun 21, 2020 6:18 pm
The tallest spring with spacer is what was fitted on my v4 mk1,
the lower springs are from a 160 mk2 petrol i broke up for boby parts but just kept springs in the shed,
I also broke up a 160 diesel springs that i have fitted at moment but it also sits low and as you can see from pictures spacer block isnt going to lift sufficiently for my liking
Adam mk1
Postby Adam mk1 » Sun Jun 21, 2020 6:22 pm
The difference in these springs are 2 3/4 inches show above
Adam mk1
Postby Adam mk1 » Sun Jun 21, 2020 6:26 pm
Adam mk1
Postby Adam mk1 » Sun Jun 21, 2020 6:29 pm
Adam mk1
Postby Adam mk1 » Sun Jun 21, 2020 6:30 pm
Adam mk1
Postby Adam mk1 » Sun Jun 21, 2020 6:35 pm
That was a factory di mk2 190 on ebay the other day see how high it sits that's what i want, i dif message seller to buy springs but he wanted to sell van as is than break it, i did consider buying complete van then break it my self, but hes sold it now
Adam mk1
Postby Ralph.9 » Mon Jun 22, 2020 6:16 am
Hi Adam, I have a pair of MK2 v6 front springs from an Ambulance & I have a complete rear end of roof from a SWB tailgate van with the closing pane.My mate Dave had that minibus & its been sold to a bus museum. Ralph
Ralph.9
Postby Adam mk1 » Mon Jun 22, 2020 11:09 am
Cheers ralph, ill give you a call this evening
Adam mk1
Postby Neil » Sat Jun 27, 2020 8:38 am
if you want it sitting high alter the shackle bars [re make /drill] a bit like a 70 s jack up kit
Neil v6
Neil
Postby Adam mk1 » Sat Jun 27, 2020 10:20 pm
I fitted 120 springs on rear with the spacer blocks and i will as you suggest once its outside all back together if im not happy with how it sits chop rear hanger and put a bit in them, i did this on rear of my mk2, put 2 inches in them but 2 inches on those doesn't lift it 2 inches!!! Because it's in the rear of spring not the middle of axle! But the mk2 sat spot on
Adam mk1
Postby Neil » Sun Jun 28, 2020 8:28 am
problem with springs is they are tempered and that wears weak with time and use,,, early mk 1 s had more layers in them 6 on the back and I think 3 on the front,, if you jack the shackles up and its just the same maybe the springs duff
Neil v6
Neil
Return to Mk 1 & 2
