I just bought a transit MK2 from 1981 and while I found the VIN without a problem (it is in the car's papers, the vehicle identification plate as well as stamped on the left of the engine compartment) I cannot make sure I really got the engine number right.
I found a few places on the internet that give you instructions where to find your engine number, but for now I got two separated identifiers, and they don't check out perfectly with the information I have.
I found the numbers on the bottom, front part of the block engine, on the left of the vehicle, about 15-20cm below the exhaust manifold.
To be completely clear, their formatting is where I am at loss. I expected something like:
- Code: Select all
GA 53 KJ 49586
while I got something like (numbers and letters modified with different numbers or letters respectively)
1st identifier (above):
- Code: Select all
4 G A
6G 1S
2nd identifier (below):
- Code: Select all
G T
2 86 53
NB: The last line of the 2nd identifier isn't perfectly aligned, it looks like it was typed with a very old typewriter.
So, does anyone have a clue about what those information could be?
Thanks a lot!
