How to remove pitmann arm on steering box ?
Postby Soren » Wed Sep 02, 2020 6:08 pm
Hi
Does any have an good ideer, How to remove pitmann arm on steering box ?
On an Transit MK1 1977 ?
I have an pullig on it and tryed with electric heat , so it was red
no sh*t happens
any ideers ?
Cheers Søren
Transit MK 1 1977 Essex V4 2,0 Autocamper
Volvo V60 D2/D3 2013
Harris Magnum 2 GPZ 1100 1984
Kawasaki GPZ 1000RX 1988
Aberdeen Angus cattle approx 35
MF 135 1973
David Brown / Case 1390 1982
Soren
Re: How to remove pitmann arm on steering box ?
Postby Neil » Wed Sep 02, 2020 6:41 pm
you need a hydraulic puller to remove the arm
Neil v6
Neil
Postby Soren » Wed Sep 02, 2020 7:06 pm
Hi Neil
Do you have an foto of it ?
Søren
MF 135 1973
Soren
Postby Neil » Wed Sep 02, 2020 9:16 pm
type it in ebay theres various types for sale on there ,,item https://www.ebay.co.uk/itm/283293907069
Neil v6
Neil
Postby Soren » Thu Sep 03, 2020 6:30 am
Hi Neil
How do you have space for an tre legs puller ??
and there is not that much space betwin wing and pit mann arm
So i think it has to be an total other kind, with only 2 arms,,,, sorry
Søren
MF 135 1973
Soren
Postby Ralph.9 » Thu Sep 03, 2020 6:54 am
I use a 2 arm Sykes Pickavnt hydraulic puller, you must not use heat as it will ruin the seals & bushes in the box. I could loan my puller for a week or so if it will help you? Ralph
Ralph.9
Postby Neil » Thu Sep 03, 2020 7:07 am
Soren wrote:Hi Neil
Søren
i use a 3 when the columns out the van
Neil v6
Neil
Postby Soren » Thu Sep 03, 2020 1:59 pm
Hi Ralph
Thanks for the offer
but i think for now i will try some other things
I will let you know how it goes
Did you get my mail about parts ?
Cheers Søren
MF 135 1973
Soren
Postby Luke » Thu Sep 03, 2020 6:10 pm
i made a couple of pullers for mine one for the pas and one for the non pas
pictures of both in here :arrow: viewtopic.php?f=3&t=8964&c=1
Postby Neil » Thu Sep 03, 2020 9:05 pm
Soren wrote:Hi Ralph
Cheers Søren
remember no heat
Neil v6
Neil
Postby Ralph.9 » Fri Sep 04, 2020 7:08 am
Cheers Søren
Yes I did get your email, I will sort the parts at the weekend.
Ralph.9
Postby Ralph.9 » Fri Sep 04, 2020 7:10 am
Neil wrote:
Soren wrote:Hi Neil
Søren
How does removing the column help remove the arm or allow a 3 legged puller?
Ralph.9
Postby Neil » Fri Sep 04, 2020 7:24 am
Ralph.9 wrote:
Neil wrote:
Soren wrote:Hi Neil
Søren
it doesnt ralph,,,, only removed the arm after ive cut the mount out the inner wing then split the two on the bench :D :D
Neil v6
Neil
Return to Mk 1 & 2
