MK2 2.4 York water temp sensor wiring
Postby Ford_V6 » Thu Sep 17, 2020 3:19 pm
Hi! :D
My water temp gauge doesn't work.
Found out one wire is missing at the sensor and it is 3 wires coming out of the same "tube".
Where do these wires go? :oops:
Ford_V6
Re: MK2 2.4 York water temp sensor wiring
Postby dumper » Thu Sep 17, 2020 4:46 pm
The temperature gauge on the York engine only has one wire to it and is near the thermostat housing the sensor in the photo looks like the one for the preheat starter system
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby Ford_V6 » Thu Sep 17, 2020 5:10 pm
Ok.
I have to look more tomorrow.
The pre-heat is disconnected from the original setup on my car. It has a switch to manually pre-heat instead.
Ford_V6
Postby Ford_V6 » Sat Oct 03, 2020 6:32 pm
I don't have any other sensor than the one in the picture.
It's the same on my other Transit as well.
Ford_V6
Postby Ford_V6 » Mon Oct 05, 2020 5:09 pm
What color is the wire to the sensor?
Ford_V6
Postby dumper » Mon Oct 05, 2020 6:16 pm
Not sure on the colour but the terminal on the end was a 90 degree female round pole type and very close to the thermostat housing on the top of the head the sender in your photo if you remove it will not let any water out as it does not go into the water jacket unlike the temperature sender does .
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Return to Mk 1 & 2
