Ralph.9 wrote:Are yours solid or vented disc's? The best upgrade if their solid is the much larger 4 pot callipers from a MK3 minibus, they are the largest you can get inside a14 inch wheel.
conrod wrote:190 LWB should have the vented discs with 4 pot calipers already. Put some decent pads (I fitted Mintex 1166 to mine) and they will be great.
If you have 4 pot calipers and solid discs, (which was an option on some vans too!) then the calipers can take a vented disc in theory, as they just have spacers fitted between the two caliper halves to make up the extra width. I say "in theory" because it will probably be impossible to buy these spacers on their own I suspect!
skerr3 wrote:Hi, you need to make you caliper wider by adding spacers, if you look at the photograph where I have marked with the arrows, you will see spacers inserted to make the two halves of the caliper wider.
The calipers mentioned as fitted to LDV convoy are also fitted to the Land Rover Defender, again be careful when sourcing parts are there are different variants, two piston or four piston, some single hose, some dual circuit.
Frollo wrote:Right. I suspect the 190 LWB is the one on your profile picture? I´m sorry im not fluent in the transit lingo, since this is the first one I´m trying to build. Do i understand you correctly by saying: If I remove the spacers, a 24mm disc will fit. I suspect that i am going to need a 280 disc to get the van approved. Do you have any links or part numbers to the parts I need? If not, i will have to google my way through.
Neil wrote:4 pot calipers is the upgrade if youve not got them now that should be plenty stopping power
