Fuse box mk2 problem
Postby Dave83 » Tue Nov 10, 2020 9:04 pm
Hello to all . I'm new to the forum, I'm Dave and I'm writing from Italy.
I bought a mk2 2.4 from 1981.
I have a problem with a possibly non-original fuse box on the side of the battery. inside there are relays and fuses. when I opened it I found some loose wires and other damaged wires.
I would like to fix this situation. could i have information on this fuse box? what is the use of what services are there? is there a wiring diagram? do you have any photos of the box? Thank you very much
Dave83
Re: Fuse box mk2 problem
Postby Neil » Wed Nov 11, 2020 8:21 am
its a fuse box off something else added later by the look of it
Neil v6
Neil
Postby Dave83 » Wed Nov 11, 2020 8:32 am
on this mk2 model originally where were the relays?
Dave83
Postby Neil » Sat Nov 14, 2020 9:18 am
under the steering wheel area on mine [not in a box ]
Neil v6
Neil
Return to Mk 1 & 2
