Hello to all . I'm new to the forum, I'm Dave and I'm writing from Italy.
I bought a mk2 2.4 from 1981.
I have a problem with a possibly non-original fuse box on the side of the battery. inside there are relays and fuses. when I opened it I found some loose wires and other damaged wires.
I would like to fix this situation. could i have information on this fuse box? what is the use of what services are there? is there a wiring diagram? do you have any photos of the box? Thank you very much
