Gearbox in an mk2 MT75 or the old overdrive
Postby Ghosta » Tue Dec 01, 2020 8:07 pm
We got a mk2 LWB twin rear wheel. The old York out and a 2,5 80ps Td in . What’s my best choise keep the old 4 speed with OD or use the MT75?
Göran i Björnarbo
Ghosta
Re: Gearbox in an mk2 MT75 or the old overdrive
Postby dumper » Tue Dec 01, 2020 8:40 pm
If the o/d box is working ok I’d keep it with it working on 3rd & 4 th it’s like having 6 gears I fitted one to my mk3 great when overtaking change up a gear with out taking your foot off the gas .And it saves messing about with the van floor I think I’ve still got a new switch for the gearstick.
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby Ghosta » Thu Dec 03, 2020 9:19 am
Thanks for your answer.
I don’t know if the figures are correct, but if they are . I think 3+OD is close to 4. Or is I’m missing something?
The overdrive is not OK today , something electric i think , checked the switch . But there’s something else messing.
In our old Volvos if there is problems with the Lycock we replace them with a 5 speed.
This is our old mk2 3500kg LWB twinweeler.
And the donor vehicle -96 mk5.
Bodywork is not a bit problem.
One idea with the camper is keeping the mechanical parts simple .
A Bosch conversion is on the schedule, I’m searching for a pump.
Göran i Björnarbo
Ghosta
Postby dumper » Thu Dec 03, 2020 10:45 am
Yes I used to miss out 4 gear changing up straight up to 4 overdrive and then dropping to 4th when needed to when go up inclines if it’s not working maybe fitting a 5 speed box will be more reliable less to go wrong.
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby Adam mk1 » Thu Dec 03, 2020 11:04 am
You can also look up ratio on doner van, with vin number for example w8 =wide ratio box, C8=close ratio, and also 5th in ether box is not the same ratio so worth comparing with your overdrive box, always thought overdrive box is like 4&a half in overdrive, so 5 speed probably better anyway
Adam mk1
Location: Live in southsea Portsmouth, work nr Winchester
Postby Ghosta » Thu Dec 03, 2020 12:59 pm
I found this .
It says 0.82:1 on 5th on both MT75. And 4th+OD. 0.78:1
I’ll check the VIN plate if a remember.
Göran i Björnarbo
Ghosta
Postby Ghosta » Thu Dec 03, 2020 2:08 pm
A also find this somewhere over the rainbow.
Another thing, I think a comfortable speed in my old mk2 is not more than 55mph.
This will be our holiday car, no stress allowed on my holiday.
The mk2 will replace this one.
Göran i Björnarbo
Ghosta
Postby dumper » Thu Dec 03, 2020 3:11 pm
I’ve driven many transits with the MT75 box and I don’t know what the gear ratios were it may have been any of them or just one of them the company I worked for would just order what body they needed and a Diesel engine.
I’d just get a good box that’s the main thing to get right if you go down the 5 speed route or get your OD box repaired mate.
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby Chug » Thu Dec 03, 2020 6:19 pm
I don't know if you've seen this site?
it's where that ratio diagram comes from
http://www.super7thheaven.co.uk/compone ... 5-gearbox/
Chug
Postby Ghosta » Thu Dec 03, 2020 7:39 pm
I found the site when a googled MT75 ratios.
VIN numbers. On my mk5.
I seen a key for reading VIN numbers, but a can’t remember where.
Göran i Björnarbo
Ghosta
Postby Chug » Fri Dec 04, 2020 9:41 am
Chug
Postby Ghosta » Fri Dec 04, 2020 12:59 pm
Thanks Chug.
Box 2 says E8 on my mk5.
Göran i Björnarbo
Ghosta
Return to Mk 1 & 2
