engine mounts on mk1 transit diesel
Postby walker tranny » Fri Oct 12, 2007 3:16 pm
l,ve got l reg 1972 transit diesel l am go to put a new 25 di in it but the engine mounts are diffrent will mk3 one fit ie the whole mount that bolt on to the side of the chassie or will l have to get later mk1 ones
walker tranny
Re: engine mounts on mk1 transit diesel
Postby Luke » Fri Oct 12, 2007 4:53 pm
i think yours will be the same as mine - the bit that bolts onto the mk3 chassis will unbolt and weld onto the mk1 chassis rail - it will be the correct width you just need to get front to back position correct :D
Postby walker tranny » Fri Oct 12, 2007 8:59 pm
so will the two bolt under the chassis bolt on and the top one have to be welded :|
walker tranny
Postby Luke » Fri Oct 12, 2007 9:03 pm
erm not sure - i know the top needs welding cos i remember doing it i dont remember bolting it on tho :? to do a pukka job there is a bit on the top of the rail that sticks out on the mk3 that you'd have to weld on extra but its fine without it :D
what i'd do is bolt the engine and box up in position with the mounts on and offer it in place - if you can pick up on any bolts then do so but at least that way it will be in the right position :D
Postby walker tranny » Fri Oct 12, 2007 9:21 pm
thanks mate will try that when get engine still looking for any other easy way thanks steve
walker tranny
Postby manandvan » Wed Dec 12, 2007 1:41 am
hi if you can get ones from a 76/77 mark one these will bolt straight on and be suitable, you can use 2.4 or 2.5 engine brackets with these, there are different rubber heights/ thicknesses throughout the years.
manandvan
Postby Neil » Wed Dec 12, 2007 5:45 pm
if its a perkins now its a headache :roll:
Neil v6
Neil
Postby walker tranny » Wed Dec 12, 2007 10:18 pm
thanks all engine in and runing now thanks a lot
walker tranny
Return to Mk 1 & 2
