Read hub swb mk2
Read hub swb mk2
Postby buxvan » Sun Apr 11, 2021 9:35 pm
You will probably laugh at me but, I thought my rear wheel cylinder was weeping as I had wetness on the bottom of the brake drum. Turned out it was the hub seal leaking out diff oil. Have bought a new hub seal & hub but as my but had been butchered (not by me) old but had 4 spaces where a special socket was needed to tighten it up. New one has about 12 sides like a socket. In the manual it says there should be a locking washer. There wasn't one fitted. Do I need one?
Now the stupid bit.
I take it that the diff oil lubricates the wheel bearings??
Thanks in advance
buxvan
Re: Read hub swb mk2
Postby Muttley » Sun Apr 11, 2021 9:52 pm
You should have 2 nuts (collars) with a lock washer in between. Nip up the inner one so as to just remove end float, put on the washer and bend a tab or 2 inwards to lock it. Then tighten the outer one up and lock that as well. Yes, splash from the diff lubricates the bearings.
Expert burns receiver.
Bodger Extraordinaire!!
Fallen in love/hate with Mk6s
Muttley
Postby Ralph.9 » Mon Apr 12, 2021 6:24 am
I have the lock washers in stock if you need them?
Ralph.9
Postby buxvan » Mon Apr 12, 2021 1:34 pm
This is the knackered hub nut & a Haynes picture of my hub. Only one nut . New nut looks different. Will the lock washer still work?
Do you bend one of the tabs or is it like a gripping star washer?
Thanks again.
buxvan
Postby buxvan » Mon Apr 12, 2021 1:37 pm
New nut
buxvan
Postby Muttley » Mon Apr 12, 2021 9:33 pm
The locking collar should have six notches in it, the tabs on the washer lock it and the spacer collar behind it. That doesn't look like the right nut to me.
Muttley
Postby buxvan » Mon Apr 12, 2021 10:28 pm
Muttley wrote:The locking collar should have six notches in it, the tabs on the washer lock it and the spacer collar behind it. That doesn't look like the right nut to me.
Thanks Mutley. Think I'll give Ralph a call tomorrow as he has everything! Cheers. (Hope you're ok)
buxvan
Postby DougT » Mon Apr 12, 2021 10:53 pm
Just in case it helps, here is the picture from the Mk1 SWB parts list.
Doug
DougT
Postby Ralph.9 » Tue Apr 13, 2021 6:44 am
That nut is MK3/MK4 which you peen over, I have some correct nuts somewhere. I will have a look today.
Ralph.9
Postby MinorMatt » Tue Apr 13, 2021 8:49 am
Ralph.9 wrote:That nut is MK3/MK4 which you peen over, I have some correct nuts somewhere. I will have a look today.
No thats a mk4/5 nut which you do up and leave alone - no peening required as its nyloc :D
Its probably a different thread, but if not it would be functional on an earlier axle (albeit not correct)
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby buxvan » Tue Apr 13, 2021 10:31 pm
When my nut arrives I'll tell you if it's the correct thread.
buxvan
Postby buxvan » Wed Apr 14, 2021 1:22 pm
I'd doesn't fit ! Larger inside diameter & there's there's no nylock.
buxvan
Postby Muttley » Wed Apr 14, 2021 9:40 pm
You deffo need the notched collar :wink:
Muttley
Postby buxvan » Wed Apr 14, 2021 9:44 pm
Muttley wrote:You deffo need the notched collar :wink:
& A nut that fits!
buxvan
Postby Ralph.9 » Thu Apr 15, 2021 12:49 pm
I have these 2 type of nuts, the one on the left is type 34 axle( Square tube) & the smaller one on the right type 32 axle(round tube) & I have the lock tab washers.
Ralph.9
Return to Mk 1 & 2
