Adding a lighter
Adding a lighter
Postby wardy-uk » Thu Oct 18, 2007 7:22 pm
I want to add a lighter socket to my Mk 1 transit to plug my sat nav in. Where should I be trying to look to wire this in at?
wardy-uk
Re: Adding a lighter
Postby viper » Thu Oct 18, 2007 8:43 pm
I would tap directly into the main power feed to ignition or take power from fuse box.
Custom interior, MK6 MWB RWD 90PS 2000)...220 000miles, parked up for 3 years rust free
viper
Postby Luke » Thu Oct 18, 2007 8:58 pm
do you want it to be on all the time or come on with the ignition :?:
Postby wardy-uk » Thu Oct 18, 2007 9:11 pm
Luke wrote:do you want it to be on all the time or come on with the ignition :?:
With the ignition if possible
wardy-uk
Postby Luke » Thu Oct 18, 2007 9:14 pm
yes its possable :D
do you have a test meter and/or a soldering iron :?:
Postby wardy-uk » Fri Oct 19, 2007 6:00 pm
Soildering Iron yes test metter no I keep meaning to get what thou looks like I will have to this time :!:
wardy-uk
Postby Luke » Fri Oct 19, 2007 6:06 pm
yeah - what you need to do is pick up a switched 12v feed from somewhere - i'll have a look on a wiring diagram to see what wire to pick but basically just solder a wire to that going via a fuse to the + terminal on the fag lighter socket and connect the - side to an earth point on the van :D
Postby wardy-uk » Sat Oct 20, 2007 10:56 am
Cheers Luke :) Ill have a look on ebay for one now :wink:
wardy-uk
Postby Luke » Sat Oct 20, 2007 11:01 am
my dad bought a test meter the other day from wicks think it was about £6 :D
Postby wardy-uk » Sat Oct 20, 2007 11:52 am
I seen a one in home base for £3.99 but I thought for that price it would be shite
wardy-uk
Postby Inline Boarding Portugal » Sat Oct 20, 2007 2:04 pm
Luke wrote:my dad bought a test meter the other day from wicks think it was about £6 :D
You can also search for that "search-light-pens"..
I can't explain better, :? but I've a "pen" with a sharp metal point, a light inside and a connection for ground on the back.
-It's great, because after connecting the back wire it to the earth (some metal point of the van...), all you have to do is to stick the sharp point it on every wire that you think may suit your needs, until you find what you need.
And it's normally way cheaper then a regular "meter"..
:wink:
Every now and then being lifted by:
-> '85 DI MK2 phase2 Grey Minibus
-> '81 York diesel MK2 phase1 White Minibus
## INLINE BOARDING PORTUGAL ##
Postby MK1Chris » Sat Oct 20, 2007 3:21 pm
Let us know how you get on Wardy-uk.
I will need to do this soon, but think I'll just have a 12v power outlet socket (ie: a cigarette lighter without the lighter bit, just a rubber bung over the top). Need it for TomTom and iPod charger and stuff like that. Will try to hide it under the dash / in the glovebox somewhere.
I am a complete novice when it comes to vehicle electrics, so hope this is fairly simple.
I'll have to study the wiring diagrams in the old Haynes manual before thinking about cutting any wires... or I might just leave it to somebody who knows what they're doing!
MK1 CI Motorhome.
Original 2Litre V4 and 4 Speed Manual with 29k on the clock (now up to 31k!)
Rusty problems soon to be sorted. See my progress in the projects section... http://fordtransit.org/forum/viewtopic.php?f=27&t=28696
MK1Chris
Postby Luke » Sat Oct 20, 2007 3:27 pm
wardy-uk wrote:I seen a one in home base for £3.99 but I thought for that price it would be shite
it will do the job mate - you'll probly only ever use 2 functions on it :D
Postby wardy-uk » Sat Oct 20, 2007 9:17 pm
MK1Chris wrote:Let us know how you get on Wardy-uk.
I don't want mine for a lighter iler just for my sat nav. I have been thinking of where I can hide it away and the glove box seems like a grate idear.
Ill take some pictures and put them on here when I do it
I think ill just buy that one from the shop then Luke save waiting foe delivery :)
wardy-uk
Postby wardy-uk » Tue Oct 23, 2007 2:30 pm
I got a tester to day for £5.99 good job as well as last night when ever i put my main beams on my lights went off :!:
wardy-uk
Return to Mk 1 & 2
