It cranks a few times then starts again, no smoke from what I have noticed.Chug wrote:Sounds like fuel starvation, when it stops will it restart straight away? or does it need cranking a bit then eventually start? any smoke when its doing this?
Runs ok for a bit then it losses power again.Chug wrote:and then runs and drives ok or keeps cutting out?
There is yes, I'll check it out in the morning. Just hope it's easy to remove.bambi mk 1 wrote:Is there a glass sediment bowl below the battery if there is there's a gauze in it that could be blocked
shawn67 wrote:There is yes, I'll check it out in the morning. Just hope it's easy to remove.bambi mk 1 wrote:Is there a glass sediment bowl below the battery if there is there's a gauze in it that could be blocked
Sent from my moto g(9) plus using Tapatalk
Ok cool..thanksbambi mk 1 wrote:shawn67 wrote:There is yes, I'll check it out in the morning. Just hope it's easy to remove.bambi mk 1 wrote:Is there a glass sediment bowl below the battery if there is there's a gauze in it that could be blocked
The knurled nut screws off at the bottom of the bowl, don't over tighten it or you can pop the glass.
What would be an alternative replacement if things come to the worse?dumper wrote:bambi mk 1 wrote:Is there a glass sediment bowl below the battery if there is there's a gauze in it that could be blocked
We used to throw them away back before the anti waxing additives where added to diesel used to be a common brake down in winter on anything that had a sediment bowl and yes be careful common for the bowls to crack if over tightened.
Checked that...was nice and clean...I take it that it is normal for the pump to be empty when I open it...bambi mk 1 wrote:Is there a lift pump on the side of the fuel pump if there is take the screw out of the centre of it and you will find another gauze
