68 mk1 gearbox reverse Switch (fitting one)
Postby NogE » Sun Jul 25, 2021 7:27 am
Hi all.....
So I'm guessing it maybe possible to fit a reverse switch to this gearbox...an early unit in my mk1 68 transit...I noticed reverse switches for 1970 vans selling online...so thought I'd ask the question about getting one fitted to my 68 van...is it doable..
Cheers..
NogE
Re: 68 mk1 gearbox reverse Switch (fitting one)
Postby dumper » Sun Jul 25, 2021 9:47 am
Have a look around the gear stick mounting there maybe a plug you remove to screw the switch into or at the top of box just below top cover of the box if it has a plug when you remove it allows the reversing switch to contact on the gear selector shaft .
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby DougT » Sun Jul 25, 2021 5:47 pm
I seem to remember that on mine before I changed gearbox, that the reverse switch was on a bracket mounted above the gearbox. The gearstick itself acted on the switch when in the position to select reverse gear. It might have been a different arrangement as it was a German firewagon with a gearbox which was hung onto the chassis with a top mount, (type F, I believe).
Doug
DougT
Postby DougT » Sun Jul 25, 2021 8:22 pm
Found a photo
Doug
DougT
Postby NogE » Wed Jul 28, 2021 6:16 pm
No blanked holes in afraid..... I'm guessing later boxes only had switch fitted....
Does anyone know if the later box side plate will fit the early box..and if reverse position will touch that switch..
NogE
Postby NogE » Sat Oct 09, 2021 6:38 pm
So.....this is the side of my box....
Can I tap this area..(rusted colour dot)
And fit my reverse switch there..as I'm assuming that's where it's located... ..
See interpart switch I hv too....
NogE
Return to Mk 1 & 2
