di won,t start
di won,t start
Postby hodgson4711 » Tue Oct 23, 2007 5:58 pm
hi, i need your help again. went out at the weekend everything ok came home parked the van up no problem next day started up ran awhile then cut out. found the neg battery lead lose and hot tightened it up but the engine won't now start. normally it starts on the button but now you have to turn the starter over about 20 times it starts revs for a few seconds then cuts out. its a bit like the problem you have with a pinto when the capacitor packs it. i dont think the battery lead is the problem although i could be wrong. regards H :cry:
hodgson4711
Re: di won,t start
Postby MinorMatt » Thu Oct 25, 2007 3:43 pm
Could be a bunged up fuel filter?
Re: di won,t start
Postby FredTransit » Thu Oct 25, 2007 4:56 pm
when was the last time you changed the oil?
FredTransit
Mk2 Trannyist
Re: di won,t start
Postby Inline Boarding Portugal » Fri Oct 26, 2007 12:03 pm
Maybe the (lonely) electric wire that connects to the fuel pump gets loose with vibration... It happens a lot on our transit!
If misconnected, may lead to erractic behaviour like the one described.. :?
Good luck!
Every now and then being lifted by:
-> '85 DI MK2 phase2 Grey Minibus
-> '81 York diesel MK2 phase1 White Minibus
## INLINE BOARDING PORTUGAL ##
Re: di won,t start
Postby hodgson4711 » Fri Oct 26, 2007 9:31 pm
thanks for the idea's i'l check them out over the weekend and let you know how i get on. regards H
hodgson4711
Re: di won,t start
Postby Luke » Fri Oct 26, 2007 9:34 pm
check you still dont have the fuel filter in the tank :!: - Di's have a seperate one so just bin the in tank one :D
Re: di won,t start
Postby hodgson4711 » Sun Oct 28, 2007 2:52 am
thanks luke ,i took that out after the last problem with fuel starvation. hasn't been a problem since. regards H
hodgson4711
Re: di won,t start
Postby hodgson4711 » Mon Mar 03, 2008 2:05 am
hi, just a update. i change the oil, it wasn't that. i changed the fuel filter it wasn't that. it turned out to be the lift pump. replaced it and it started more or less straight away. now its crunch time do i spend another £1000 or get another van with less rust? thanks again for all the help H
hodgson4711
Re: di won,t start
Postby FredTransit » Wed Mar 05, 2008 6:44 pm
hodgson4711 wrote:hi, just a update. i change the oil, it wasn't that. i changed the fuel filter it wasn't that. it turned out to be the lift pump. replaced it and it started more or less straight away. now its crunch time do i spend another £1000 or get another van with less rust? thanks again for all the help H
Huh? If you are looking to spend a grand you would be looking at a Mk5, and they have hearly as much rust as the Mk1 and the Mk2!
FredTransit
Mk2 Trannyist
Return to Mk 1 & 2
