Fitting rear slaves (Is there an easy way to do them clips)?
Postby NogE » Sat Sep 11, 2021 8:21 pm
Bleeding me brakes today...took me hours getting that dam air out....it's great now...after realising one slave had a slight leak...New one fitted now..the times used was fitting that dam rear backplate springy clip thingy...is there a nack to it..was there a ford tool?
NogE
Re: Fitting rear slaves (Is there an easy way to do them cli
Postby dumper » Sat Sep 11, 2021 8:35 pm
All I used to do was make sure the backplate surfaces are clean so that the grove in the cylinder is fully visible and push it upwards ether with a large screwdriver/ pry bar / or tap it up with a punch which ever works on the day may have even done them with a pair of water pump Plyers.
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby NogE » Sun Sep 12, 2021 8:17 pm
Hi dumper,
Yes used a screwdriver..all very clean underthere to.....wonder if there was a tool tho.. :?: 8
NogE
Postby dumper » Sun Sep 12, 2021 9:52 pm
I’ve never seen one but it’s not to say they’re not a tool that will do it somewhere I think it was the only van at the time we had on the fleet with this type of clip we mainly had Fords so the transit is the only one I can remember with it.
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby V184 » Sun Sep 12, 2021 10:08 pm
dumper wrote:I’ve never seen one but it’s not to say they’re not a tool that will do it somewhere I think it was the only van at the time we had on the fleet with this type of clip we mainly had Fords so the transit is the only one I can remember with it.
I've got one, think its a sykes
V184
Postby dumper » Mon Sep 13, 2021 6:15 am
If I got a difficult one I did have a special tool I remember now it’s called get the apprentice to do it :lol:
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby Soren » Mon Sep 13, 2021 6:35 am
Me Too,,,, :D
Søren
Transit MK 1 1977 Essex V4 2,0 Autocamper
Volvo V60 D2/D3 2013
Harris Magnum 2 GPZ 1100 1984
Kawasaki GPZ 1000RX 1988
Aberdeen Angus cattle approx 35
MF 135 1973
David Brown / Case 1390 1982
Soren
Postby NogE » Mon Sep 13, 2021 6:16 pm
REALLY..
.please can u put up a pic...maybe..would help lots..
NogE
Postby V184 » Mon Sep 13, 2021 6:54 pm
REALLY..
pm me a phone number and i will wattsapp you pictures
V184
Postby NogE » Tue Sep 14, 2021 6:11 am
Pm sent
NogE
Postby V184 » Wed Sep 15, 2021 2:32 pm
NogE wrote:Pm sent
for some unknown reason i cant get messages :?
V184
Postby Luke » Wed Sep 15, 2021 5:05 pm
V184 wrote:
NogE wrote:Pm sent
where are you looking? no ones PM's have been turned off :?
Postby V184 » Wed Sep 15, 2021 7:14 pm
Luke wrote:
V184 wrote:
NogE wrote:Pm sent
You are not authorised to read private messages.
V184
Postby Luke » Wed Sep 15, 2021 7:24 pm
V184 wrote:You are not authorised to read private messages.
weird, try it now :?
Postby V184 » Wed Sep 15, 2021 7:26 pm
Still the same, You are not authorised to read private messages.
V184
Return to Mk 1 & 2
cron
