Mk1 68 .electrical questions
Postby NogE » Thu Sep 16, 2021 8:58 pm
Hi all...
When I connect my live to battery my nearside front and rear lights come on...even with ignition off...I was thinking parking light but Donno if we had that in a 68 mk1,, but, these would normally work by lifting indicator arm up ..thing is I don't hv the indicator arm fitted yet????..
Also...got to thinking about brake lights...do I hv a brake light switch somewhere in the bay peddle area??
NogE
Re: Mk1 68 .electrical questions
Postby dumper » Thu Sep 16, 2021 9:06 pm
If the pedals hang down from the steering column area it will be on the bracket for the pedals inside the cab but if the real early one that come up through the floor I don’t know.
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby Neil » Thu Sep 16, 2021 9:17 pm
faulty wireing somewhere, auto sparky???
Neil v6
Neil
Postby DougT » Fri Sep 17, 2021 2:11 pm
Fuse 3 is for the left side sidelights, front and rear plus instrument lights and "accessories". Fuse 2 is for the right side. The wire from the light switch should feed both fuse 2 and 3.
If you pull out fuse 3 then you can tell which side of the fuse box the problem lies. My suspicion is that one or other of fuses 2 or 3 is not making good contact or it has blown plus there is something in the instrument panel or something like a radio where the wiring is sending power back to the fuse box.
If the fuses were good and making contact then you would expect both sides to be lit up so that would be my first check and then try to see how power is getting there. Depends if various thing have been added as accessories and how well they have been wired up. Can't think what could cause it but a bad earth connection can divert power to unexpected places.
Wiring diagram is here although there are different ones "up to 68" and "68-70"
www.fordopedia.org/
Also gives cable colours.
Doug
DougT
Postby dumper » Fri Sep 17, 2021 3:08 pm
I can’t remember where the fuses are on the mk 1 but on the mk2 the ceramic fuses used to be bad for corrosion half the time if one was bad the rest would be as bad at work with not having to pay for them we used to change them all after spraying the box with electrsolve .
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby NogE » Fri Sep 17, 2021 5:48 pm
Thanks guys...gonna spend the weekend looking into all this and yr advice will.be very useful...
NogE
Postby DougT » Sat Sep 18, 2021 10:46 pm
I have found a useful set of diagrams here:
http://www.mgb-stuff.org.uk/servo.htm
which explain the operation of the remote servo. So with engine running but no pressure on the brake pedal the vacuum needs to get to the back of the servo as well as the front and this is controlled by the air diaphragm. I think I would have a check that you are happy with the air diaphragm unit as any air leaks would seem to cause the brakes to come on. But that doesn't explain how disconnecting the pedal helps.
Doug
DougT
Postby DougT » Sat Sep 18, 2021 10:47 pm
wrong post ! will repost in the right place !!
DougT
Postby NogE » Sun Sep 19, 2021 12:31 pm
All electrical problems listed are fixed now...earthing.. :lol:
Now new one in looking at is indicators..when I flick arm in a position I hear flasher unit click..tho no flashing lights...suspect is the flasher unit first I'm guessing..
NogE
Postby dumper » Sun Sep 19, 2021 1:20 pm
If I remember correctly it will a small round one clipped under the dash
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby NogE » Sun Sep 19, 2021 7:46 pm
Hi damper,..yes..it's not that small ,well my one ain't ...three terminals.... are most flasher units online universal?
NogE
Postby NogE » Mon Sep 20, 2021 6:34 pm
Hi all... update here ..
Indicators working now..terrible earth problems..plus bulbs main tips had flattened off... sorted now...
I've a couple of dash cluster probs now.. I can't get main beam blue light to come on ..obvious things tested..bulb,power,earths ..the pcb on back of clock has been removed and cleaned..and I'm defo getting voltage over to the main beam bulb..(blue window)...however, when I put meter across there I only get 9.57volts..
Can people tell me, the voltage regulator,..what happens when it plays up?
NogE
Postby DougT » Mon Sep 20, 2021 11:38 pm
Dodgy voltage regulator will tend to mean that fuel gauge and temp gauge will rise and fall with engine revs when they should be stable. Alternator kicks voltage up with revs so more current through the gauges.
If you checked the voltage across the bulb unit then try checking from positive on the bulb to a good chassis earth on the dash. If voltage still low then it is probably a connector somewhere. It seems that you have a few dodgy connections, bulb tips and earths due to van not being used, so maybe worth just swapping bulbs around.
Doug
DougT
Doug
DougT
Postby NogE » Tue Sep 21, 2021 6:26 am
Thanks Doug...
Wow,I remember back in my days of my mk2 cortina having that problem with meter needles moving up with revs :lol: ..never did fix that...thought it was normal..that was back in 83 ....
I'm on van today...no paying work at mo..and I love it....tho I do get frustrated when rain stops play...those with workshops are so lucky...well maybe that's the wrong word ....I just jealous..
I do get frustrated when I spend all day trying to sort one problem, but then again what I sort today I don't hv to sort tomorrow :wink:
NogE
Return to Mk 1 & 2
