Carbs.. right and wrong ones..
Postby NogE » Wed Nov 03, 2021 4:44 pm
Can people start giving model makes/numbers for the correct carbs used on v4 1700 ,2000 and pintos....be a good thread I think.... also might help me out as I hv 5 different units in a box here...pictures would be great too...
NogE
Re: Carbs.. right and wrong ones..
Postby Neil » Wed Nov 03, 2021 10:18 pm
what have you got ?
Neil v6
Neil
Postby NogE » Fri Nov 05, 2021 10:35 am
Hi Neil....
NogE
Postby NogE » Fri Nov 05, 2021 11:43 am
I hv a feeling this is wrong ..it's for lower cc unit....I need o check jets me thinks
NogE
Postby Neil » Sun Nov 07, 2021 9:44 am
yours should be a zenith 36 downdraught carb the carb bodys the same for 1700 and 2000 its the jets that vary
Neil v6
Neil
Postby NogE » Mon Nov 08, 2021 5:27 pm
Cheers Neil,,,
I used the fomoco top that was on the van when I purchased it..i used this to keep the return to the tank pipe ...it had a 165 jet which I kept in that top....
This should still be ok for this 1700 I guess as the body looks the same inside and out....hope I'm correct in saying this.. van runs ok...recon mix needs setting up abit
NogE
Postby Neil » Tue Nov 09, 2021 10:01 pm
1700,,,,,,, main jet 92 -slow running jet 55- compensating jet 112- fuel enrichment jet 110-accelerator pump jet 55
Neil v6
Neil
Postby NogE » Wed Nov 10, 2021 11:03 am
Hi Neil....
Thank you.... I'll hv to assume all's the same in the original carb top...I did replace the main jet only with same one that was in it.. it says 165 on it.. the rest I cleaned and aired it out...the numbers you give me are for the zenith unit yeah...?
NogE
Postby Neil » Thu Nov 11, 2021 8:10 am
yes zenith fitted to 1700
Neil v6
Neil
Postby NogE » Tue Nov 16, 2021 7:32 am
Thanks Neil
NogE
Return to Mk 1 & 2
