Webber 38DGMS for Low Compression Essex V6
Postby edmason » Wed Feb 09, 2022 7:14 pm
I have a 1972 Land Rover Lightweight with a V6 Essex Low Compression Transit Engine (Steve Parker Land Rovers in Whitworth did a popular conversion back in the day).
Mine has a Weber 38DGMS carb, which is giving me problems, so I'm wondering about replacing it. There are lots of 38DGMS available set up for Scimitars & the like, & I'm wondering whether they will suit the LC engine.
Apparently Weber say they have no information about the 38DGMS & the Low Compression engine.
The standard set up on new carbs seems to be either
27mm chokes
4.0 Auxillary venturi
135 Main jets
50 Idle jets
185 Air correctors
55 Pump jets
F50 Emulsion tubes
250 Needle valve
Eurocarbs 38DGMS
or
Main jet 142
Air jet 185
Idle jet 45
Em.tube F50
Pump 55
FastRoadCars 38DGMS
Does anyone have any experience with Webers and the Transit V6 please?
edmason
Re: Webber 38DGMS for Low Compression Essex V6
Postby Neil » Wed Feb 09, 2022 7:41 pm
yep dont bother :!: the webber isnt jetted for the low comp engine and will give niggles either find a right single carb for it or a granada engine
Neil v6
Neil
Return to Mk 1 & 2
