and with no transit engine
i have engine, suitable bellhousing, clutch and 5 speed type 9 gearbox (sierra)
but problem is that gearstick output is far too behind and i need to work out how to move that more forward
first idea was to cut and weld but that is lot of work and only 7..8 cm / ~3 inch difference - in the picture the middle version
next thought was use another gearbox tail section like in that picture that would help me too its around 25 cm / 10 inch
last i found that in transit they used type 9 gearboxes where gear stick is on top of gearbox are this MK2 ?
so is this gear selector part on market and can it be attached on sierra type 9 box
or is whole transit type 9 gearbox (5 speed) something that i can find on the market (last gear ratio ~0.
more good thoughts ?
anyway where i live there is limited sources and i have to find my parts from Uk or Germany or ...
