16" wheels for a mk2?
Postby jckm2000 » Mon Oct 17, 2022 12:42 pm
Hi Folks,
My mk2 swb motorhome has piddly 14" wheels.
I've experimented with landrover wheels and adapter plates but I'm not happy with the arrangement.
Does anyone here know if later transit wheels in either 15 or 16", 5 stud will fit?
Cheers,
C.
MK1 V4 flatbed (long gone)
1978 MK2 pinto
1996 MK5
2003 MK6 (now gone)
1967 Morris WF
jckm2000
Re: 16" wheels for a mk2?
Postby conrod » Mon Oct 17, 2022 9:22 pm
5 stud or 6 stud ?
conrod
Postby jckm2000 » Mon Oct 17, 2022 9:29 pm
Sorry, 5 stud.
1978 MK2 pinto
1996 MK5
2003 MK6 (now gone)
1967 Morris WF
jckm2000
Postby Keef » Tue Oct 18, 2022 8:46 am
I'm pretty sure Transit Custom and MK8 wheels will fit & come in 15" & 16"
Unlike MK6/7 wheels, they are studcentric which i assume MK2s are but they have 14mm studs so you would need wheelnuts with a larger taper.
They are common and cheap enough to buy one to experiment with.
Keef
Postby conrod » Tue Oct 18, 2022 10:45 am
yep the Custom wheels are the same stud pattern, but offset will be wrong so will need a fairly thick spacer/adaptor I imagine. And by then, you may as well swap the bolt pattern on the adaptor to something more available!.....
conrod
Postby Keef » Tue Oct 18, 2022 3:06 pm
MK2 wheels are 5.5Jx14 ET39.5
Custom wheels are 6.5Jx15 (or 16) ET60
I'll let someone else do the maths, scroll down when the page opens.
https://www.wheel-size.com/calc/?wheel1 ... 0mm&sr=0mm
Keef
Postby caldwelld » Fri Oct 21, 2022 8:30 pm
Hi , mk 8 wheels 16 inch fitted directly on to my Mk 1 transit campervan. Get the nuts for the mk8 wheels as well.
caldwelld
Return to Mk 1 & 2
