problems starting my mk1
Postby shepped0 » Sat Nov 26, 2022 11:22 pm
Hi All
Looking for a bit of guidance
Owned my petrol v4 1969 Transit for a long time now but only recently i am having some issues when i start it.
The van resides in my garage and gets started every 2/3 weeks just to ensure everything is good.
Recently i have struggled to get it started having to turn it over many times before it starts.
I know this is down to a fuel issue as i can use easy start and it will cough and splutter and then go without issue.
This problem only seems to occur if i have left the van without starting it for 3 weeks or so. It feels like there is a problem getting fuel from the tank to the engine..as though it has evaporated in the fuel line .
I dont recall this to be a problem before..maybe cranking a few times but never this long
Any help or guidance much appreciated
David
shepped0
Re: problems starting my mk1
Postby Neil » Sun Nov 27, 2022 10:34 am
could be fuel draining back into the tank with standing? thought of an electric pump maybe , there is a in line non return valve you can fit also , if i leave mine a few weeks you can hear the pump taking time to prime so a manual pump will be even longer
Neil v6
Neil
Postby shepped0 » Wed Dec 07, 2022 8:58 pm
Neil wrote:could be fuel draining back into the tank with standing? thought of an electric pump maybe , there is a in line non return valve you can fit also , if i leave mine a few weeks you can hear the pump taking time to prime so a manual pump will be even longer
Thanks Neil long time no speak how are you?
Yes maybe a non return valve is the way to go any advise on where and what to buy any links most welcome
Kind Regards
David
shepped0
Postby Neil » Thu Dec 08, 2022 8:27 am
hello david , yes not bad thanks , yourself ? heres something on ebay number https://www.ebay.co.uk/itm/111887419952&seller=&toolid=10018&17153357" rel="nofollow">https://www.ebay.co.uk/itm/https://www.ebay.co.uk/itm/111887419952
Neil v6
Neil
Postby shepped0 » Sun Dec 11, 2022 1:22 pm
Neil wrote:hello david , yes not bad thanks , yourself ? heres something on ebay number https://www.ebay.co.uk/itm/111887419952&seller=&toolid=10018&17153357" rel="nofollow">https://www.ebay.co.uk/itm/https://www.ebay.co.uk/itm/111887419952
Thanks Neil I have ordered one
shepped0
Return to Mk 1 & 2
