mk1 brake servo
mk1 brake servo
Postby gringo » Mon Dec 26, 2022 12:36 pm
has anyone information on getting a replacement brake servo for a mk1.
i normally have to pump the pedal once or twice so it doesnt go down too far when braking, does this mean the servo is on its way out ??
its a mk1 one transit campervan, 1972, has front disc axle.
thanks
gringo
Re: mk1 brake servo
Postby Altransit » Tue Dec 27, 2022 3:19 pm
Your symptoms sound more like air bubbles in the fluid :? If the servo isn't working, the pedal would normally go hard with no braking assistance.
You can check the servo by pumping the pedal (engine off) until the pedal goes hard, then, by continuing to hold down the pedal and starting the engine, the servo should move the pedal down taking away that hardness :)
Re: mk1 brake servo
Postby gringo » Thu Dec 29, 2022 7:43 pm
thanks for the reply altransit.
today i pumped the brake couple times with the engine off, then started the engine still pressing down on the pedal,
the pedal went a further down and the force got softer.
i think i understand what you were explaining so my next job in the next week or so is to bleed the brakes on all four wheel cylinders with new brake fluid.
thanks again
gringo
Re: mk1 brake servo
Postby Chug » Fri Dec 30, 2022 12:39 pm
If the brakes get better by pumping the pedal it could be adjustment needed, (usually the rear adjuster siezed/not working properly) pumping the pedal takes up the adjustment.
Chug
Re: mk1 brake servo
Postby Altransit » Fri Dec 30, 2022 12:52 pm
Chug wrote:If the brakes get better by pumping the pedal it could be adjustment needed, (usually the rear adjuster siezed/not working properly) pumping the pedal takes up the adjustment.
Yes, good point Chug.
If the rears have auto adjusters, then they're notorious for not working properly, and need freeing off or manual adjustment :)
Re: mk1 brake servo
Postby fortyeight » Mon Jan 16, 2023 2:30 pm
while your bleeding the brakes change the fluid
fortyeight
Re: mk1 brake servo
Postby muneeb transit » Mon Sep 11, 2023 4:43 pm
WE HAVE ALTERNATIVE SERVO AND CYLINDER THAT COULD USE FOR LIFE TIME SHIPPING AVAILABLE
MUNEEBAUTOS@GMAIL.COM
WWW.MUNEEBAUTOPARTS.COM
muneeb transit
Return to Mk 1 & 2
