None starting V4
None starting V4
Postby wardy-uk » Tue Nov 27, 2007 5:14 pm
I think she might have got some water in the Carb :?
Shes been running grate for ages now but just won't start now. Shes got a full tank and a fully charged battery. She turns over quickly but will not start any one anyidears?
wardy-uk
Re: None starting V4
Postby Neil » Tue Nov 27, 2007 5:48 pm
fuel pump working :?: contacts not broke :?:
Neil v6
Neil
Postby wardy-uk » Tue Nov 27, 2007 6:00 pm
Just tryed it there is petrol coming throught when I take pipe off and run it. Whats the contacts?
wardy-uk
Postby Wolfie » Tue Nov 27, 2007 6:01 pm
points.
condensor
resistor
1979 2L pinto camper
Wolfie
Postby wardy-uk » Tue Nov 27, 2007 6:08 pm
How would I tell if they are not working?
wardy-uk
Postby Luke » Tue Nov 27, 2007 6:25 pm
check for a spark 1st - take a plug out and rest it on a manifold turn it over see if it sparks :D
Postby Luke » Tue Nov 27, 2007 6:26 pm
connected to a plug lead of course :wink: :lol:
Postby wardy-uk » Tue Nov 27, 2007 6:35 pm
:lol: I know my mechanical nolage is not to good but I know the plug as to be in the lead lol ill give it a try now and let you know :)
wardy-uk
Postby wardy-uk » Tue Nov 27, 2007 6:42 pm
Just tryed I got a nice clear blue spark
wardy-uk
Postby wardy-uk » Tue Nov 27, 2007 6:45 pm
Does that mean my electrics are ok?
wardy-uk
Postby madmark » Tue Nov 27, 2007 8:11 pm
:roll: does she try to start then stop when you let go of the key?????? :?:
Postby wardy-uk » Tue Nov 27, 2007 8:27 pm
She will try to start to I let go of the key :?
Its a real shame as when I first got her I loads of problems with every thing but not a thing now :x
wardy-uk
Postby Luke » Tue Nov 27, 2007 8:29 pm
wardy-uk wrote:Does that mean my electrics are ok?
yeah sort off - i'd look at petrol next - is it getting to the cylinders :?: when you took out the plug did it look damp :?:
Postby wardy-uk » Tue Nov 27, 2007 8:45 pm
Could not tell it was to dark ill try having a look tomorrow. I did put some easy start on but it still would not go. Ill also have another look at the petrol tommorow and let you know how I get on :)
wardy-uk
Postby Luke » Tue Nov 27, 2007 9:09 pm
dont bother with easy start :!: fix the problem then you wont need it :wink:
if i have a probelm with starting the towrope comes before easy start :lol:
Return to Mk 1 & 2
