serial number on chasis? Anybody knows where to search?
Postby pjotrvox » Sun Dec 02, 2007 5:10 pm
Hi! Everyone!
It is my first time to enter the forum. Until now I was only silent observer. For a half a year I am in a project of restauration of my Ford transit MK1, 1968, made in UK wit 2,0 essex engine. Rust was removed with high preasure sanding and after it was painted with ground colour. Before we put next layers of colour, we want to find the chasis serial number.
Does anyboy have a clue, where this could be? Thank you for your time and help!
Peter
pjotrvox
Re: serial number on chasis? Anybody knows where to search?
Postby Neil » Sun Dec 02, 2007 5:36 pm
square plate on the bulkhead under the bonnet
Neil v6
Neil
Postby pjotrvox » Sun Dec 02, 2007 5:55 pm
Neil wrote:square plate on the bulkhead under the bonnet
How to say... first of all thank you for reply! I´vechecked the dictionary but your description doesn´t help me. Sguare plate I have, but there should be some serial number ingraved into the chassis, like they exist on machine. For example - here is the link where german transit have it... ( http://www.transit-stammtisch.de/index.html )
I´ve screched down the arier, but no luck...
Maybe english producer put it somewhere else?!
If it is posible, can you give me more detailed description? Picture of location?
Thank you,
Peter
pjotrvox
Postby transitgeoff » Sun Dec 02, 2007 6:02 pm
Hi my 1969 does not have a number stamped into the chassis anywhere, if yours is an English built it wont have it stamped or ingraved anywhere, the later ones had it on the spring hanger :D
transitgeoff
Postby pjotrvox » Sun Dec 02, 2007 6:07 pm
transitgeoff wrote:Hi my 1969 does not have a number stamped into the chassis anywhere, if yours is an English built it wont have it stamped or ingraved anywhere, the later ones had it on the spring hanger :D
Thank you, now I don´t have to vaist my time in searching - I hope, that the oficer for registration will accept this hYstorical fact.
Regards,
Peter
pjotrvox
Postby Neil » Sun Dec 02, 2007 8:01 pm
if you have the square plate all the information is on it
Neil v6
Neil
Postby pjotrvox » Sun Dec 02, 2007 9:46 pm
Neil wrote:if you have the square plate all the information is on it
For me it makes sense, but you didn´t experiance our birocracy :)
I hope it will do...
Peter
pjotrvox
Postby FredTransit » Tue Dec 04, 2007 1:18 pm
On the later Mk1 phase2, they were in the left (our passenger side) over the spring hanger on the chassis over the wheel. It's not easy to see with all the bodywork in place!
FredTransit
Mk2 Trannyist
Postby pjotrvox » Tue Dec 04, 2007 2:05 pm
FredTransit wrote:On the later Mk1 phase2, they were in the left (our passenger side) over the spring hanger on the chassis over the wheel. It's not easy to see with all the bodywork in place!
You have all the answers - thanks again!
P.
pjotrvox
Postby FredTransit » Tue Dec 04, 2007 2:32 pm
I hope you don't see the chassis number how I see it, ours was bought accident damaged so now has no wing on it. If you remove the wheel and put your head in the wheel arch, you should be able to see it.
FredTransit
Mk2 Trannyist
Return to Mk 1 & 2
