Hi All,
i have done all the checks i can think of.
my engine is a 2.5di fitted in a mk2 that's being rebuilt after refurb hence having to connect everything up.
engine originally had a plastic thermostat housing with a twin wire sensor. didnt work when the other wire of the sensor was earthed. found out thermostat wasn't working not that it makes any difference. Changed thermostat housing to a metal one and fitted new single wire sensor white ring. (not sure which one it should have) still doesn't work.
put the temp sensor in boiling water, still nothing.
earthed both live wires of the fuel and temp gauge. The dials work. If the dials work at this point does it mean that the voltage regulator in the clocks is working??
fuel sender is new also.
put spare set of clocks in. dont know if they work or not they are just spare. still nothing changes.
any ideas what could be wrong or further test to do?
on a side note the heater matrix appears internally etc in good nick, both pipes to it are very hot but also dont get any heat into cab.
any help would be gratefully received.
