Finally got my Transit running well enough to take a short test ride. Afterwards, I noticed that it was leaking coolant around the large hose to the thermostat housing. Was planning on ordering a new hose, but needed to measure the dimensions first (seems to be 45 mm one end, and 40 mm the other end). But there is a large hole right under where the hose clamp has been:
It seems to be made of aluminium or something. Not magnetic. I wonder if it would be possible to weld it? Or maybe some kind of epoxy, like jb weld?
Do you have any idea?
