Mk1 brake servo
Mk1 brake servo
Postby greek » Thu Apr 04, 2024 5:56 pm
Hi Guys been surfing for a Brake servo Mk1 found nothing anyone have any alternatives that might fit. looked at LDV sherpa found a couple everything else same as Transit so thinking maybe these will be. Heads up on anything be good Thanks
I`m to old to lie under Transits
greek
Re: Mk1 brake servo
Postby Mr twin choke » Fri Apr 05, 2024 10:10 pm
Have you tried; https://www.brakesint.co.uk/contact_bolton.html
They had no problem supplying me with a master cylinder and rear wheel cylinders so are worth contacting. I have a MK2 servo ready to fit onto my MK1. It is a bit larger and after a test fitting found it fits straight on. This may be another option for you.
Mr twin choke
Re: Mk1 brake servo
Postby greek » Sat Apr 06, 2024 2:41 pm
Yes i have used that company a few times forgot will look again . My problem might be with a Mk2 one if there a lot bigger i have a Leisure battery Servo side so limited on space & not a lot of Mk2 about either Thanks though will keep looking.
greek
Re: Mk1 brake servo
Postby Neil » Sat Apr 06, 2024 7:17 pm
mk 2 servo will fit on mk 1 you can always get your servo rebuilt ,,,,, the bendix on the mk 2 is slightly larger
Neil v6
Neil
Re: Mk1 brake servo
Postby Ollie » Sat Apr 20, 2024 5:14 pm
https://www.classiccar-brakes.co.uk/about-us/
These guys talk sense for rebuilding old units, I presume you have a core unit to rebuild? mine will be going there next week!
Ollie
Ollie
Re: Mk1 brake servo
Postby greek » Thu May 23, 2024 4:42 pm
Sorted guys new old stock for LDV just a shorter push rod easy fix
greek
Re: Mk1 brake servo
Postby Ollie » Fri Oct 11, 2024 8:39 pm
Before i forget, when I picked up my rebuilt mk2 master cylinder from contract auto, they mentioned that the mk1 servo shares lots of bits with dolomites for which they rebuild servos, there is apparently a non available fragile plastic cup around the push rod so dont bust that, but they are working on remanufacturing them so if you need bits then hopefully it'll improve soon.
Ollie
Return to Mk 1 & 2
