mk2 Swaybars /anti roll bars
Postby Trynader » Wed Jul 03, 2024 4:04 pm
Hello fellow transit owners,
I would like to fit sway bars to my 1980 transit twin wheel. I have found a sway bar for an mk8 ford that is also a twin wheel. On these the sway bar is mounted at the back of the schock brackets. The mk2 happens to have the same ones, just without holes. The center-to-center on the brackets measures to about 65 [cm], the mk8 sway bar about 75 [cm]. The sway bar looks to have have enough straight bar left to slide both of them 5 [cm]. Then al that is left is to make some simple brackets to where the sway bar links connect to.
So the back sway bar is pretty easy, now I need a solution for the front.
An mk8 would have the link about as wide where the shocks mount. Those links would then be to long for comfort. Maybe using a rear sway bar from a single-wheel mk is the solution, the frame rail in the font are about 95 cm wide from center to center if i remember my message correctly.
I would like to hear if one of you has a better idea.
Best regards,
Kevin
1980 Transit mk2 LWB
Trynader
Re: mk2 Swaybars /anti roll bars
Postby dumper » Wed Jul 03, 2024 5:39 pm
It may be worth looking at if you can find one the 35 hundred weight A series we had two in the 80s they where a total waste of time as a pickup compared to a transit carried less weight but they did have a front anti rollbar
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby conrod » Wed Jul 17, 2024 10:05 am
K-Mac in Australia can supply you a front and rear bar for a LWB Mk2. They made me a set a few years back, and I got them to go a bit larger on the rear and front than their listed size. I bolted the rear through the shock mounts too as you suggested, the rear was supplied with "U" bolt mounts which I didn't like.
conrod
Postby Ralph.9 » Thu Jul 18, 2024 7:04 am
I have a complete MK1 or MK2 Transit front anti roll bar kit, im away untill tomorrow so I can get some pictures when I return home?
Ralph.9
Postby Neil » Sun Jul 21, 2024 8:11 am
i have one for sale in the parts section
Neil v6
Neil
Postby Trynader » Tue Jul 23, 2024 8:43 am
Ralph.9 wrote:I have a complete MK1 or MK2 Transit front anti roll bar kit, im away untill tomorrow so I can get some pictures when I return home?
Sure, how much do you want for it and would you be able to ship it to the netherlands?
Trynader
Postby Ralph.9 » Wed Jul 24, 2024 7:17 am
I will get a price to ship to you.
Ralph.9
Postby Ralph.9 » Wed Jul 24, 2024 4:21 pm
I have messaged you.
Ralph.9
Return to Mk 1 & 2
