engine number 2.5di
engine number 2.5di
Postby mk2 transit crew » Wed Jul 24, 2024 8:30 pm
Hi All,
i have had a look on the forum and looked at various suggestions and the only "numbers" i can find on a 2.5di banana non turbo are above/behind the alternator and the one i think is an engine number is 3 numbers,a letter, a hyphon followed by 4 numbers and 2 letters. I should mention the engine came out a ldv so possibly different arrangement then ford.
Any help on how many letters/numbers i should be looking for and any potential locations. the only place i haven't checked is the flange of the sump which i will look at tomorrow.
thankyou in advance.
mk2 transit crew
Re: engine number 2.5di
Postby Altransit » Thu Jul 25, 2024 4:31 pm
So far as I can remember, it is behind the bracket bolted to the block, which supports the power steering pump. I can't remember if you have to remove the bracket to see it, but It's a row of numbers, (can't remember how many) but should match the last numbers in your VIN number, unless LDV do it differently. :!:
Postby dumper » Thu Jul 25, 2024 8:27 pm
It’s also possible on the block behind the fuel filter but I may be thinking about genuinely Ford exchange engines they had a plate stuck to the block in that region you had to remove the filter element to get a good look at it
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby mk2 transit crew » Fri Jul 26, 2024 11:25 pm
Hi,
thankyou for your suggestions, i have ended up finding it. it took a long time!! it is in dot form letters and is stamped into the lip on the edge of the block where the sump connects under the starter motor, next to the gearbox. it is stamped LDV 4HB XXXXX. so it looks like due to the donor vehicle being a ldv it is in a different place to a ford. every area i checked online said as altransit has confirmed that it can be found on a ford 2.5di near where the power steering bracket is fitted. i found a picture confirming this online also.
mk2 transit crew
Return to Mk 1 & 2
