Hi guys,
I have some trouble with my DI camper. I have not been driving around all too much the last couple of years which may have caused the problems.
The engine starts quickly and is idling fine but when I'm revving up the engine fully, it stutters somewhat below the max rev it should reach.
Sometimes it gets to the max rev after 4 to 6 seconds and sometimes it even reaches max rev quickly in one step like it should be.
While driving there seems to be less power and also frequent stuttering when trying to drive the gears fully out to max speed.
I can't adjust the correct idle speed of 850 rpm either. If I do, the engine tends to starve and go off. Also after fully revving up, the engine comes down but tends to keep idling with somewhat higer rpm. If I then try adjusting the idle screw to get down to 850 rpm it will suddenly come down and again tend to go off. It's as if there is some bump in between too high idling and engine going off.
So far I have done:
- cleaning of the Tank (had brownish sticky residues on the bottom)
- new diesel filter
- new fuel hose
- tank filled up with fresh diesel
- added 250 ml Liqui-Moly diesel cleaner in tank
Also, I shoud mention that last year I had the filter assembly changed and fitted an universal screw on assembly because the primer pump on the original Lucas assembly was defective. Doing that I screwed in a standard pipe adapter for an 8mm fuel hose on the Lucas CAV pump. Usually there is a fuel hose adapter for a 6 mm hose with some sort of plastic sealing. I don't know if this change may cause problems with the pressure sensor in the Lucas CAV.
I'd appreciate any help or experience on this issue.
Thanks!
ps: please excuse if my english is not perfect, I'm from Germany.
