Delphi fuel hose connector
Postby peteMK2C » Tue Aug 06, 2024 6:24 am
Hi there!
I need one of those Delphi Fuel hose connectors that go deep into the joint. Those are mounted with a hollow screw that squeezes a rubber ring which then seals the joint.
Where can I buy those connectors?
They have been used frequently as a standard connector for plastik fuel hoses on the 2.5 DI Diesel engine.
Greets,
Pete
peteMK2C
Re: Delphi fuel hose con
Postby dumper » Tue Aug 06, 2024 9:18 am
You could try a motorfactors that do Hgv parts or a company that makes hydraulic pipes they usually do air and fuel pipe components
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Re: Delphi fuel hose connector
Postby peteMK2C » Tue Aug 06, 2024 10:26 am
Thanks! I'll try that.
peteMK2C
Return to Mk 1 & 2
